Activity Forums Apple Final Cut Pro Legacy HDV Conundrum.. Compressor /Toast Titanium
  • HDV Conundrum.. Compressor /Toast Titanium
    Posted by Pradip Patil on August 19, 2010 at 6:15 pm
    Hi guys.
    Just finished a HDV 1080 50i project. And Exported a 1 minute video as a self contained movie. Then I used compressor (BEST Quality DVD:90 mins). But the quality of the output was below par.
    Wherever there was fast motion in the video, it all appeared with extreme jagged edges.
    And when I used the same mov file in Toast Titanium directly, the output that I got was much better compared to Compressor.
    So for the day my purpose is solved. but I am confused.
    Isn’t compressor designed to avoid exactly the kind of thing that I am getting from it.
    And earlier I have had very bad outputs from the Toast Titanium and HDV combination but compressor worked fine.
    So what has happened now?
    What’s the problem?
    Michael Gissing replied 16 years ago 5 Members · 7 Replies
  • 7 Replies
  • John Fishback
    August 19, 2010 at 6:34 pm
    You might check the field order in the Inspector. Compressor may set this “automatically” and get it wrong.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Pradip Patil
    August 19, 2010 at 6:40 pm
    Ok.. so I should set it to Upper, right?
    I played with couple of frame controls but not FIELD ORDER.
    Thought automatic would be best.
    And Thanks for the quick reply John.
  • Chris Borjis
    August 19, 2010 at 7:00 pm
    see what it is in the settings in final cut.
    hd is usually upper, but pal dv is lower.
    also make sure in compressor the resize filter is on and set for best.
  • Pradip Patil
    August 19, 2010 at 7:06 pm
    Hmm…
    So the compressor setting refers to source format or the output format?
    HDV is upper first format then should my compressor setting be UPPER ? or should it be LOWER as the final output is expected to be SD?
    Pradip Patil
    Mumbai,India
  • Chris Borjis
    August 19, 2010 at 9:13 pm
    [Pradip Patil] “HDV is upper first format then should my compressor setting be UPPER”
    yes.
  • Chris Tompkins
    August 19, 2010 at 11:12 pm
    You used a 90 minute preset for a 1 minute video.
    Adjust your data rate accordingly.
    Chris Tompkins
    Video Atlanta
  • Michael Gissing
    August 19, 2010 at 11:29 pm
    All HD and all SD except DV is upper in 25fps. Automatic should work but set to upper and all will be good.
