Activity › Forums › Apple Final Cut Pro Legacy › HDV ‘Conform’ and Blackmagic HD Pro
  • HDV ‘Conform’ and Blackmagic HD Pro
    Posted by Paul Ingvarsson on August 25, 2005 at 8:44 pm
    Hello,
    Just a quick one, I’ve heard that to output an HDV timeline back to HDV tape a lengthy ‘conform’ or render needs to take place (presumably to construct a new MPEG GOP stream).
    I use the Decklink HD Pro card in my dual 2.7 G5 – If I output to HDCAM via HDSDI would I still need to do this ‘conform’ process??
    Paul
    Freelance DS/Symphony
    London
    Steve Connor replied 21 years, 1 month ago 3 Members · 2 Replies
  • David Roth weiss
    August 26, 2005 at 1:41 am
    Paul,
    The conform process is for outputting HDV back to the HDV camera or to an HDV deck. In my limited experience doing that, it seems to take about six times realtime. If you are editing native HDV on the timeline, and outputting that to HDCAM via HDSDI, you should probably render the entire sequence out to HDCAM in advance, simply to avoid the posibility of dropped frames. There are complex calculations going on in real time when playing back HDV, and I think you actually save time by rendering, because you’ll be confident that everything will be right when going to tape. If someone else thinks the render is not necessary please feel free to make that point…
    DRW
  • Steve Connor
    August 26, 2005 at 10:52 am
    You have to render if you want to be sure of no dropped frames, theoretically it’s possible to just output in real time via HDSDi, but I haven’t been brave enough to try a whole show!
    Steve Connor
    Cardinal HD
