Activity Forums Adobe After Effects HDV comp settings
  • HDV comp settings
    Posted by Gray Wilson on July 30, 2008 at 5:51 pm
    Hi there, got a question. I have a Sony HVR V1U that records HDV 1080 24p with a 2:3 pulldown. I transcode the HDV upon capture to ProRez which removes the pulldown. I then close Final Cut and import the ProRez files into After Effects for effects work. My clip however always looks fat. I make a comp with the clip and it uses a custom HDV/dvcproHD (1.33) setting. I’ve played and played with it but it always looks fat. However when I export it and open in Final Cut it looks beautiful. Do I just need be happy that it ultimately works or is there a way to make it look correct while I’m working on it.
    Much Thanks,
    Gray
    Gray Wilson
    realgraycreative.com
    Gray Wilson replied 18 years, 1 month ago 23,753 Members · 1 Reply
  • Gray Wilson
    July 30, 2008 at 9:38 pm
    Thats it! It was the pixel aspect ratio button. Didn’t think of that. The image was squeezed, but now it looks great.
    Thanks again,
    Gray
    Gray Wilson
