Activity Forums Apple Final Cut Pro Legacy HDV capturing problems…please help…why the subclips?
  • HDV capturing problems…please help…why the subclips?
    Posted by Ryanservant on June 27, 2005 at 9:50 pm
    So I have read that if you shot with the Z1 on quick record that FCP would use some sort of scene detection to create subclips. I am using a FX-1 and when I try and set in and out points to capture an entire tape it goes through the whole tape and creates a lot of subclips every place I hit the record stop start button. I did not view footage while shooting and the clips are not timecode breaks because the subclips are in perfect line when it comes to the timecode. Meaning one clip will end in 02:04:05 and the next clip will be 02:04:06. This would be a cool feature if and when it found these subclips that it would capture them. As of right now it goes through the whole tape adding all of these subclips, then only captures the very last subclip. I then have to highlight all of these newly created subclips and batch capture them. These means that on a 45 mintue tape I have let the Computer go through the tape TWICE. This sucks
    anyone have any clue whats up?
    Ryan
    I am using tiger and fcp 5
    G5
    xserve 2.5 TB
    FCP HD
    2 gigs ram
    Used to be Kona Hd…Now its Decklink HD pro
    Ryan Servant
    AirSeaLand Productions
    http://www.airsealand.com
    718-626-2646
    Dustin Lau replied 21 years, 2 months ago 4 Members · 3 Replies
  • Sandust
    June 30, 2005 at 8:03 am
    Aloha,
    If anyone knows how to disable this, PLEASE let me know. I offlined a 90 minute project using HDV captured to DV and now I need to online in HDV, but can’t!!!!! I can’t recapture the enitre tape because of the new clip thing. I have tried media managing the project, but even with only 10 frame handles we get extra clips that mess things up.
  • Ivan George
    July 1, 2005 at 3:05 am
    From what I understand your recording to standard DV tapes. That’s the same thing that’s happening to me. Try using the HDV tapes and see if this works.
  • Dustin Lau
    July 2, 2005 at 9:31 pm
    It still occurs even if you use HDV tapes
