Activity Forums Apple Final Cut Pro Legacy HDV Capturing Problems: HVR-Z1U to FCP 5
  • HDV Capturing Problems: HVR-Z1U to FCP 5
    Posted by A2red on December 9, 2005 at 8:17 pm
    Hi all,
    I’m currently working on a project that I’ve shot on 1080i on the Sony Z1U, but downcoverted to SD to edit. I’m ready to re-capture everything in HDV, but when I connect the firewire i-link to my dual 2.7 G5 and load up the capture window I get the following message:
    “Unable to Initialize Capture Device and Device Control
    Device is not connected or the capture preset and device control preset are not setup correctly. You may still log offline clips.
    This might also happen if you play DV footage in an HDV device.”
    More info:
    Sequence Preset: HDV-1080i60
    Capture Preset: HDV
    Device Control Preset: Sony HDV Firewire
    Also, I’ve noticed that in the camera lcd screen, the format is “DV” when final cut is running. When FCP is not running, the format gives the correct “HDV” reading.
    Standing Point Films: Michigan Based Independent Film Production
    http://www.standingpoint.org
    A2red replied 20 years, 9 months ago 3 Members · 3 Replies
  • Paul From apple
    December 10, 2005 at 5:29 pm
    Please use the deck’s downconvert options in the menus. Then create a new project using the standard DV NTSC (or PAL) presets. Once the deck is setup to downconvert, FCP will see it as any other DV deck and you’ll be able to control it.
    Paul Saccone, Product Manager
    Final Cut Studio
  • Travis Ballstadt
    December 10, 2005 at 9:44 pm
    Have you changed your Easy Setup to the HDV option? Sounds like you’re still working in a DV project, from your offline. Now that you’re ready to online, you’ll need to either change your setup, or Media Manage over to a new project which is set to HDV settings.
    travis ballstadt
    http://www.thrillcateditorial.com
  • A2red
    December 12, 2005 at 7:55 pm
    Thanks folks. I implemented Paul’s suggestions and tweaked the settings on my camera and it works now. Thanks!
