Activity Forums Apple Final Cut Pro Legacy HDV Capturing Clips
  • HDV Capturing Clips
    Posted by Andy Lancaster on September 13, 2008 at 3:51 pm
    Is there a way to capture an entire HDV tape in FCP? It keeps capturing individual clips. I’m assuming a new clip is made each time the camera starts and stops. I plan on using Automatic Duck to go to share with Avid so I need it to capture an entire tape as 1 file because that is what the Avid did.
    Andy Lancaster replied 17 years, 11 months ago 2 Members · 2 Replies
  • Michael Gissing
    September 13, 2008 at 11:45 pm
    [Andy Lancaster] “Is there a way to capture an entire HDV tape in FCP”
    If there are no actual timecode breaks in the tape, then yes you can capture a whole tape. In the capture window, check in the tabs. You will find an option for breaking the shots at camera stop/starts. Uncheck this box.
    Please don’t ignore actual timecode breaks. They do occur on HDV a bit and a workflow that includes recapture will suffer if you ignore them. As you are AutoDucking to AVID, I would consider the likely hood of the need to recapture is high. I have used AD to go AVID to FCP and getting media across has been difficult with recapture needed.
  • Andy Lancaster
    September 15, 2008 at 5:32 pm
    that did the trick. thanks.
