Activity Forums Apple Final Cut Pro Legacy HDV captured in FCP usable on PC?
  • HDV captured in FCP usable on PC?
    Posted by Matt Wafaie on February 5, 2006 at 7:44 am
    Is there a way to get codecs for footage captured in FCP 5 for a PC? I used to play footage captured in FCP 4 on PC all the time but it won’t work with FCP5 footage. HDV is especially needed. I desperately need this footage to work and I can’t afford a deck rental to capture it in AVID xpress pro HD. Any information is appreciated, even “you just can’t do it.”
    Shane Ross replied 20 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    February 5, 2006 at 9:38 am
    As a general rule, you shouldn’t capture footage on one edit system for editing on another. Stick to one edit system. And while this might have worked with DV in the past, HDV is another beast entirely. That might have to be captured ONLY by the system it is being used on, because of the way it needs to be decoded.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
