Activity Forums Apple Final Cut Pro Legacy hdv captured as dv needs render?
  • hdv captured as dv needs render?
    Posted by Stu Siegal on January 23, 2007 at 3:23 pm
    Shot 1080i, had the cam output as dv, captured as 29.97 ntscdv anamorphic. Sequence settings ntsc dv 3:2, no anamorphic checked. Shouldn’t it just be like regular dv material? Where did I go wrong – what should audio video & sequence settings be?
    First time trying this, it’s got me a bit confused.
    G5 Quad Core, 4.5 MB RAM, Dual Dell 1905FP’s, KRK RP-5’s, DSR-11, FC Studio 5.1.2 OSX 10.4.8
    Stu Siegal replied 19 years, 8 months ago 3 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    January 23, 2007 at 4:39 pm
    If you captured anamorphic why is your sequence settings not anamorphic?
    Just use the easy set up, before you capture and create your sequence.
  • David Smith
    January 23, 2007 at 5:03 pm
    You didn’t mention which camera you’re using. I know that the Sony HDV cameras offer choices on how you do the downconversion. You can output SD anamorphic (Squeezed in Sony speak) or a 4:3 letterbox. If you used anamorphic you should use the DV Anamorphic easy set-up and your file should have the anamorphic check box checked. If you output a letterboxed signal then use DV NTSC set-up and the check box should not be checked.
    Actually, you really didn’t say what the problem is at all. What’s wrong with the file?
    Regards,
    David
  • Stu Siegal
    January 23, 2007 at 6:10 pm
    Using a canon cam, an hv10, which is in fact where I think I made my mistake. There was no problem with the file, it all just required rendering, which it shouldn’t have. The mismatch was on the capture side.
