Activity Forums Apple Final Cut Pro Legacy HDV capture woes?
  • HDV capture woes?
    Posted by Andy Blondin on April 18, 2006 at 9:11 pm
    Okay so I’m trying to capture some HDV footage from a Sony HDR-HC1 camera. Here is what I’m doing. 1) Start a new project. 2) go to Final Cut Pro/ Easy Setup. Choose HDV. 3) I get this error. “Codec not found. YOu may be using a compression type without the corresponding hardware card.” 4) When I capture video. The frame is black and I’m getting audio.
    I can capture under Apple intermediate codec, but I don’t have batch capture capabilites. Pleas help.
    Specs. iMac G5 2GB ram, Radeon 9600 128mb, FCP 5.0 Thanks in advance
    Craig Alan replied 20 years, 5 months ago 3 Members · 4 Replies
  • Steve Connor
    April 18, 2006 at 9:32 pm
    We had this, you have to reinstall quicktime and FCP to fix it.
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Andy Blondin
    April 18, 2006 at 9:41 pm
    Thanks, I’ll have to try it later tonight. That kinda stinks. Can you just do QT or do you have to do FCP also. Thanks
  • Steve Connor
    April 18, 2006 at 11:11 pm
    I actually reinstalled the OS, Quicktime and FCPro. I just used it as an excuse to “clean up” my system!
    Steve Connor
  • Craig Alan
    April 19, 2006 at 4:40 am
    Make sure your camera is set to export footage as HDV. Check in the cam’s menus.Sony lets you choose between dv and hdv.
