Activity Forums Apple Final Cut Pro Legacy HDV Capture Query
  • HDV Capture Query
    Posted by Neil Gregory on May 12, 2005 at 4:14 pm
    Moo to you all.
    I have recently started using the Sony Z-1 Camera and have just shot some identical footage on DV and HDV to compare the difference in quality.
    I understand that capturing HDV into FCP 4.5 HD should not present any problems as this camera has a ‘Down Convert’ function.
    However when capturing the DV footage is recognised as normal but the HDV footage causes an error message in the capture window (no timecode).
    The only way I have found to get the footage onto the system is to select the ‘Convert HDV to DV’ setting in the i.Link menu in the camera. But is this simply converting the HDV footage back to DV resolution / quality?
    Does anyone know a simpler solution?
    Please help
    Neil
    Steve Connor replied 21 years, 4 months ago 4 Members · 3 Replies
