Activity Forums Adobe Premiere Pro HDV Capture quality issues.
  • HDV Capture quality issues.
    Posted by Liam Hammer on September 13, 2010 at 6:16 am
    I just attempted to capture some 1080i footage into premiere via firewire. The file that it saved, though, has severely reduced quality when played back (in a sequence with the same settings). I’ve doubled checked the capture settings, and they’re set to HDV and the correct camera make. When importing into Final Cut on another machine the footage comes out fine, as well.
    Any ideas on how to fix this? I can’t seem to find any sort of quality or format settings beyond the ‘HDV or DV’ choice in the settings tab.
    Jon Barrie replied 16 years ago 3 Members · 3 Replies
  • Ann Bens
    September 13, 2010 at 8:43 pm
    Make sure your sequence matches the footage.
    Set Playback to highest resolution and Fit.
  • Liam Hammer
    September 13, 2010 at 11:27 pm
    Already double checked both, with no improvement.
  • Jon Barrie
    September 13, 2010 at 11:57 pm
    Hi Liam,
    Can you post a screen grab of the premiere interface with your clip and the FCP interface with your clip on the same frame for comparison/troubleshooting. It would be greatly beneficial if we can see the specs (info) of the clip in each Applications interfaces.
    HDV primarily is not captured into PPro but rather the exact digital signal is ingested (transferred) to PPro. FCP captures the signal and converts it to it’s own Apple Intermediate codec (HDV) which is not the original recording data at all.
    I am very interested in seeing your results side by side with some info details.
    – Cheers, Jon Barrie
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
