Activity Forums Apple Final Cut Pro Legacy HDV capture, ProRes render?
  • HDV capture, ProRes render?
    Posted by John Wilson on August 4, 2008 at 8:24 pm
    I captured a project in HDV and am curious about the upside of rendering in either DVCpro HD or ProRes HQ. Will that make a difference or do I need to recapture?
    Chris Poisson replied 18 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    August 4, 2008 at 9:20 pm
    If you set an HDV native sequence to render to ProRes, (type cmd+zero to open that sequence’s settings and choose the processing tab to change this) you’ll speed up render times by about 40%… and with no visible picture quality loss.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Chris Poisson
    August 4, 2008 at 10:38 pm
    What Jerry says is true, but if you have the drive speed and space you are better off capturing to ProRes.
    Have a wonderful day.
