Activity Forums Apple Final Cut Pro Legacy HDV Capture Problem
  • HDV Capture Problem
    Posted by Keithinator on June 16, 2008 at 3:09 pm
    Gosh, I feel left out. Two posts on the same issue, no responses.
    https://forums.creativecow.net/readpost/8/992729
    If no one has a solution, does anyone know where I might find a solution? I’m not even sure Apple supports 5.1.4 any more. Any recommendations for an A-level technician at Apple who might be able to help? Any other advice?
    I’ve got some time pressure here, so any responses would be much appreciated. I’d hate to have to use my PC for editing, but that’s what I’ll be forced to do if I can’t solve this problem.
    Peter Hall replied 18 years, 2 months ago 4 Members · 4 Replies
  • Tim Vaughan
    June 16, 2008 at 3:37 pm
    Hi Keith
    In the log and capture window, the second tab at the top right, (Clip Settings) you’ll see a check box for “Create new clip on Start/Stop”. Be sure this is unchecked if you desire to capture the clip as a whole. I log quite a bit of HDV footage on a regular basis, and really haven’t had a problem capturing. We are using Sony Z1U HDV camera’s. Hope this helps
    Tim
    Tim
  • Rafael Amador
    June 16, 2008 at 3:45 pm
    Hi Keith,
    I’m not sure because I do not work with HDV, but I think the solution my be FC6.
    Here are the release notes:
    https://www.apple.com/support/releasenotes/en/Final_Cut_Pro_6.0_rn/
    There are some imformation about support for JVC HDV cameras.
    Maybe is what you are looking for.
    Good luck.
    Rafael
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Keithinator
    June 16, 2008 at 4:27 pm
    Hi Tim,
    Yeah, I’ve tried that. No dice.
    Rafael, thanks for the link. It may be worth shelling out for the upgrade.
    Keith
  • Peter Hall
    June 16, 2008 at 10:12 pm
    Isn’t the SONY EX-1 basically a glorified HDV codec?
    cheers, Pete
