Activity Forums Apple Final Cut Pro Legacy HDV capture problem
  • HDV capture problem
    Posted by John Martin on February 7, 2008 at 4:39 pm
    I’m capturing from an HDV tape into FCP on all the appropriate settings, HDV 1080i60, with the devices and presets all correct. However after I capture it appears horribly once in the canvas. The individual quicktime files look and play fine and there is no rendering once I drag clip into canvas. Any thoughts? Is there a ‘low-res’ viewing option that maybe I toggled accidentally?
    Chris Poisson replied 18 years, 7 months ago 3 Members · 2 Replies
  • Zane Barker
    February 7, 2008 at 4:50 pm
    What are your time line settings?
    Don’t let technology get in the way of your creativity!
  • Chris Poisson
    February 7, 2008 at 5:09 pm
    The canvas does not display both fields unless it’s at 100%, and even then it is not the place to be judging quality. You need an HD monitor or a card which can downconvert it such as a Kona.
    Have a wonderful day.
