Activity Forums Apple Final Cut Pro Legacy HDV Capture Presets in FCP 5.0.4
  • HDV Capture Presets in FCP 5.0.4
    Posted by Magicknight on June 14, 2006 at 4:05 am
    Hi All,
    I am trying to capture 4 CH audio from a Canon XL-H1 into FCP 5.0.4.
    Does anyone know what settings to use to set up a Custom Preset?
    The capture preset for HDV can not be EDIT’ed or DUPLICATE’d.
    Although, capturing twice is not an efficient workflow, for now I would be happy if I could atleast capture CH1/2 on first pass and then select second pair and recapture a second time with CH3/4.
    I would prefer not to downmix to maintain control over each channel in FCP. If I wanted to do this, I assume I select “Digital In” and “32.000 kHz 16-bit 2-chan”.
    I am studying the Canon docs to see if the firewire output can be config’d for CH1/2 for CH3/4.
    Arrrrrgh.
    Magicknight replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
