Activity Forums Media 100 HDV Capture issues
  • HDV Capture issues
    Posted by Marcus Warren on October 17, 2013 at 3:58 am
    I am having problems capturing HDV video shot in 60i on a Canon XH-A1. I have tried capturing on a 15″ MacBookPro and a 21.5″ iMac, both with 4 GB RAM and Media 100 Suite 2.1.
    I noticed in setting up for capture that there is not an HDV 1080 60i option; HDV 1080 29.97 is the only option. When I try to capture I repeatedly get the Temporary Loss of Video Sync warning and no video in the monitor.
    Deferred capture makes no difference.
    I can capture in SD, but not HDV. What am I doing wrong?
    Both computers run very sluggishly when the A1 is attached (via Firewire). They even run sluggishly even when the attached A1 is not playing video. Very strange. I need to capture the footage in a few hours because I have to return the camera.
    I guess I could capture in SD and transcode to HD but I would rather not do that. I have tried to capture to two different hard drives as well, but no luck.
    Robert Stone replied 12 years, 10 months ago 2 Members · 4 Replies
  • Robert Stone
    October 17, 2013 at 7:12 am
    Aloha Marcus – On your camera, make sure your output is set to HDV and that down conversion is off. That’s in the SIGNAL SETUP menu.
    Blessings,
    Robert C. Stone
    https://HippieFilm.com
    https://MauiTVSpots.com
  • Robert Stone
    October 17, 2013 at 7:18 am
    Also – I’m assuming that you chose ProRes codec for HD and Video Input is HD Firewire HDV? The ProRes codec should be less strain on your system than trying to CODE/DECODE HDV. Eliminates the long GOPs.
    HTH
    Robert C. Stone
  • Marcus Warren
    October 19, 2013 at 4:37 pm
    Hi Robert, I had indeed done all that you suggested before I posted. Interestingly, I went and shot test footage in 30f and 24f and they captured with no issues, so I shot additional test footage at 60i and it captured with no problems. So I went back to the original tape and uploaded it with no further issues. I have no idea what changed, but as I mentioned in the first post I initially tried two different computers with two different licensed installs of M100 Suite and it just flat wouldn’t work.
    Thanks for taking the time to troubleshoot with me.
  • Robert Stone
    October 19, 2013 at 4:56 pm
    Aloha Marcus – sometimes MAGIC HAPPENS! Glad it worked out!
    Blessings,
    Robert C. Stone
