Activity Forums Apple Final Cut Pro Legacy HDV capture into FCP
  • HDV capture into FCP
    Posted by Damian Dunne on October 18, 2005 at 6:39 am
    Hey guys,
    Im fairly new to using HD with FCP 5. I have a Sony HDV 1080i camera that I want to capture footage off without having to downsample it to DV. Can anyone gimme a hint on what the correct codec is to use so as to avoid the need to down sample……
    thanx in advance!
    Damian
    Damian Dunne replied 20 years, 11 months ago 4 Members · 6 Replies
  • Shane Ross
    October 18, 2005 at 6:42 am
    Look in the Easy Setups. There are a few to chose from….
  • Damian Dunne
    October 18, 2005 at 6:59 am
    yeah i tried most the codecs but I still dont seem to be getting any picture in the log and capture window. I can control the camera though no image.
    thanx
  • Shane Ross
    October 18, 2005 at 7:14 am
    Ooooo. I had this same issue the other day with the Panasonic 1200HD DVCPRO HD deck.
    Go to the VIEW menu and make sure that EXTERNAL>ALL FRAMES is selected. Dang it…there is one other one to check too, View>External…playback device or something (sorry, not near an FCP machine). Try that, see what happens.
  • Steve Connor
    October 18, 2005 at 8:28 am
    What format is the footage?, what system to you have? etc etc We really need more details to be able to help.
    Make sure your deck/camera has iLink downconvert set to OFF and the tape format is HDV not auto.
    Then try HDV PAL 1080i easy setup, capture some material even though you see no picture in the log and capture window and see if it plays back on the timeline.
    Steve Connor
    Cardinal HD
    Please fill in your profile – it helps US to help YOU!
  • Kevin Monahan
    October 18, 2005 at 7:57 pm
    That one gets ’em everytime.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Damian Dunne
    October 19, 2005 at 1:32 am
    thanx guys thats was all very helpful!
    So I can capture off my camera and I can get a clip onto my timeline that plays fine. Though when I’m capturing it seems that instead of FCP taking me to the log and capture window it brings up a small HDV window that only allows me to name my clip. Then it proceeds to capture my footgae on the fly.
    The story so far!!! Thanx guys for the help!
    Damian
