Activity Forums Adobe Premiere Pro HDV capture in PP 1.5.1 – increasing sound mismatch the longer I capture
  • HDV capture in PP 1.5.1 – increasing sound mismatch the longer I capture
    Posted by Normann on September 27, 2005 at 9:23 am
    I have a very bad problem with captured HDV material over PP’s HDV plug-in. I have just captured about 17 full HDV tapes (via HVR-Z1E) and everything seemed perfect at first. But when I started editing I noticed that sound and video sometimes mismatched. So I checked every captured file and it was true: the further I slide to the end in the timeline, the greater the mismatch between video and audio got. At 1 hour of the footage file there was a mismatch of about 3 – 4 seconds!!
    Please help! Has anyone made similar experiences?
    PC:
    dual Xeon 3,2
    2 GB RAM
    SATA drives RAID 0
    Steven L. gotz replied 20 years, 12 months ago 3 Members · 5 Replies
  • Steven L. gotz
    September 27, 2005 at 3:39 pm
    This is a common problem. It is suggested that you either use Scene Detect to keep the captured clips short, or you manually capture in shorter portions. A few minutes at a time.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Normann
    September 27, 2005 at 4:40 pm
    Thanks for your reply!
    So when I understand you correctly, everybody has this problem with HDV an PP and there is no solution? I mean an other solution than capturing short parts? I have about 13 hours of material containing some long interviews that dont’t need to be cut. How do the other editing programs handle HDV? Is there a better software for HDV-editing without this sound/video mismatch?
    Normann
  • Steven L. gotz
    September 27, 2005 at 4:48 pm
    You might want to ask that question on the HDV forum.
    Steven
  • Redgum
    September 28, 2005 at 1:33 pm
    Steven,
    How common is the problem? I’ve just captured four HDV tapes (all interviews) around forty minutes each and no loss of sync. Half way through an edit I found two short interviews out of sixty odd (less than a minute each) that were out of sync in the project box (in other words, when previewed). Any ideas on what causes this problem?
    Redgum Television Productions
    Broadcast & Corporate Documentaries
    Brisbane, Australia
  • Steven L. gotz
    September 28, 2005 at 1:42 pm
    Tim Kolb answered it better than I ever could over in the HDV forum.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=162&postid=856647
    Steven
