Activity Forums Apple Final Cut Pro Legacy HDV Capture in FCP
  • HDV Capture in FCP
    Posted by Brian Bacardi on July 9, 2009 at 9:15 pm
    Greetings all-
    I have a question hopefully someone might be able to shed some light on. When capturing HDV footage in FCP, there is a setting to toggle on if you want FCP to make a new clip at every start/stop point during recording. I recently purchased a Canon HV-40, and have been sucessful in capturing in all three methods (clip, now, and batch). However, I have not been able to get the above mentioned start/stop feature to work. Any ideas why?
    This is what I’m using:
    Mac Pro 2 X 2.8 Ghz Quad
    FCP 6.0.6
    Canon HV-40
    1080 24p HDV
    Any help would be GREATLY appreciated!
    Brian-
    Jon Mitchell replied 15 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    July 9, 2009 at 10:07 pm
    Hi Brian,
    Not sure if that work with HDV (I don’t work with this format).
    In the “Mark” menu you have “DV start stop detect”.
    rafael
    http://www.nagavideo.com
  • Brian Bacardi
    July 10, 2009 at 5:37 am
    Thanks Rafael-
    yes, that capture setting is currently only available in FCP for the HDV codec (as far as I know). It’s in the capture settings tab when the log and capture window is open. Anyway, I was hoping that someone might be able to tell me if it’s a FCP issue, or my camera.
    Thanks for your input.
    Brian-
  • Ian Liuzzi-fedun
    July 10, 2009 at 4:15 pm
    It’s an FCP thing
  • Brian Bacardi
    July 10, 2009 at 5:22 pm
    Hey Ian-
    Thanks for your response! So, if it’s a FCP issues, is there some sort of preference setting I need to adjust to make it work? I know this feature does work because I have seen it done in a couple of tuts. More specifically, I saw a person doing a capture with the “capture now” method. While the capture was happening, you could see FCP make and label a new clip in the bin every time there was a start/stop in the recording.
    I greatly desire to do this so I can save wear and tear on my camera. I usually will capture the whole tape, and then go back and make sub clips of what I need (very time consuming).
    Again, any help would be appreciated!
    Brian
  • Rafael Amador
    July 10, 2009 at 5:49 pm
    Hi Brian,
    Please have a look to this:
    https://www.dvinfo.net/conf/non-linear-editing-mac/86438-hdv-editing-w-fcp-importing-creates-new-clip-s-s-detect.html
    They are trying to get rid of the Start/Stop detection. It may helps you to find the solution.
    If not, Google “HDV Start Stop detection’, ther are few things.
    Cheers,
    rafael
  • Chris Poisson
    July 10, 2009 at 10:36 pm
    Capturing to ProRes (which you should be doing anyway) will do what you want.
    https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
    Have a wonderful day.
  • Brian Bacardi
    August 19, 2009 at 3:39 pm
    Hey Chris-, Thanks for your reply! I followed the instructions on your tutorial, and was able to capture to ProRes just fine (also in real time, and not with any delay). The problem is, FCP is still not making a new clip at each start/stop. To remind you, my camera is a Canon HV-40. Any other thoughts as to why this might not be working?, Also, I was wondering if you could tell me why it’s better to switch HDV to ProRes? I have heard this before, but didn’t know what the advantages or ProRes, or disadvantages of HDV were., Any help would be greatly appreciated., Brian Bacardi-
  • Jon Mitchell
    November 7, 2010 at 1:20 am
    Has anyone found an answer to this…
    I can capture video, but it does not make clips at every start/start..
    (Hv40)
