Activity Forums Apple Final Cut Pro Legacy HDV capture in Express
  • HDV capture in Express
    Posted by Neal on July 11, 2007 at 4:21 am
    Need insight. Trying to capture HDV in Express 3.5. Followed instructions of choosing HDV1080i60 from the easy start menu but dialog box never came up. Instead a capture-like window appears with Cueing video, hit escape to stop. No problem capturing
    dv, but problems with HDV Any suggestions?
    Tom Wolsky replied 19 years, 2 months ago 2 Members · 1 Reply
  • Tom Wolsky
    July 11, 2007 at 8:58 am
    I can’t tell from your description, but it sounds as if the application is behaving correctly. There is a very limited capture window for HDV material in FCE. There is no machine control. The deck has to be controlled manually. You press the Now button when the deck is rolling. Capture is not real-time has the file is being converted to AIC, but capture/conversion continues after playback stops. It’s described more fully in he help menu.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
