Activity Forums Apple Final Cut Pro Legacy HDV – capture card needed?
  • HDV – capture card needed?
    Posted by Ken Pugh on December 15, 2005 at 9:20 am
    A newbie question – I’ve been working with FCP and DV happily for a couple of years but thinking of going HDV for the next project. Do I need a capture card? FCP5 claims its HDV native – does that mean I can edit using the computers built-in firewire interface and the Sony HDV edit deck? What would a card give me other than extra interface options (that I don’t at present need)? I’m content to monitor in SD for now, although a budget HD monitor solution would also be good to know about. LCD perhaps?
    Thanks, Ken.
    Todd Beabout replied 20 years, 9 months ago 4 Members · 5 Replies
  • Todd Beabout
    December 15, 2005 at 3:16 pm
    You can capture HDV through FireWire, either from the camera or a deck with FireWire port (which they all should have).
    -Todd Beabout
    Vazda Studios
  • Shane Ross
    December 15, 2005 at 3:34 pm
    Todd is correct.
    As for a “budget HD monitor solution,” I’m afraid that you are looking at close to $4,000 for that. $500 for a decklink HD card (As HDV cannot be monitored out thru firewire like DV can), and minimum $3500 for a very low end HD monitor.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Ben Oliver
    December 15, 2005 at 3:40 pm
    i always edit using crappy monitors for the following reason.
    cost
    and the idea that if it looks great on a crappy screen, then imagine what it must look like on a real monitor.
    ……..godi hate working in indy-land GIMME THE GEAR!
  • Ken Pugh
    December 15, 2005 at 4:06 pm
    OK, but can you edit with it as well, in real time, without any hardware assistance – and if so, do you get the same level of real-time functionality I’ve come to expect from using the dv-25 (SD) codec?
  • Todd Beabout
    December 15, 2005 at 5:02 pm
    This depends on your setup. I have a G5 Dual 2.0 and I was able to work with it in realtime. You probably won’t get quite the realtime support that you get with DV25, but that is to be expected. As resolution increases, realtime capabilities decrease.
    -Todd Beabout
    Vazda Studios
