Activity Forums Apple Final Cut Pro Legacy HDV capture –
  • HDV capture –
    Posted by Sean Schiavolin on September 29, 2006 at 7:44 pm
    This is my first time on an HDV project and I have a rented M25U HDV deck and my G5 Dual2G. I am using easy setup HDV 1080i60 and am connected via firewire. I have deck control but no picture and when I make a clip and capture it captures black.
    It seems that this is a commen problem but I still cannot pinpoint the issue in my particular case. I have the settings on the deck set at 1080i60 and HDV and ilink off. Something else fishy is that the TC on th
    Jerry Hofmann replied 19 years, 12 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 29, 2006 at 9:26 pm
    Are you sure the recording is 1080i60? Might try trashing your prefs and using the easy setup for HDV 1080i… Post which camera shot it, and could you get that camera to capture with?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
