  • Posted by Kevin Herrin on February 8, 2006 at 7:53 pm
    Hi all, I am capturing a HDV source using the HDV setup, I want to capture the whole tape using Capture Now. The problem I am having is when I review the footage later there is video missing. It seems where the tape was stopped during original recording is where I am missing the video, it’s like 2 or 3 seconds at the beginning and end of the cut. I hope this makes sense, I have looked all over for a setting and I can’t find one.
    Thanks for the help
    Kevin
    Kevin Herrin replied 20 years, 6 months ago 3 Members · 3 Replies
  • Tim Baker
    February 8, 2006 at 9:06 pm
    Are you using the HD100 and did you change frame settings or camera settings at different points?
    It will lag between camera setting changes…should not if you are just starting and stopping record.
    Tim Baker
    Chameleon Mobile Video Productions
    (239)849-3295
    “It is not the light at the end of the tunnel that we should seek…it is the courage to take the next step in the dark that we must find.”
  • Liam Stephens
    Hi yeah i had a similar problem with HDV but it would make a new clip at every cut in the original recording. There was actually NO missing footage though. There isn’t a pre roll or a post roll thing going on is there?
  • Kevin Herrin
    February 8, 2006 at 9:20 pm
    The camera settings hadn’t changed, I am not sure about the pre & post roll, I am using the HD50 deck. Liam, you said that it made clips…that’s what I have going on. When I drag the clips to the timeline and apply the timecode reader there are up to 5 seconds missing between the two clips. I will change the roll settings and see if that does it.
    Kevin
