Activity Forums Blackmagic Design HDV camcorders with ATEM
  • HDV camcorders with ATEM
    Posted by Liudas Vasaris on February 15, 2012 at 11:43 pm
    I’m interested in using HDV camcorders (canon xha1, sony fx1 etc.) with ATEM switchers. As i know ATEM already suport SD, so with 720 x 576/50i resolution I shouldt have any problems, right?
    What about 1440 x 1080/50i? Would ATEM recognize this as 1080i50? If conecting XHA1 to ATEM via BM analog(component)->SDI maybe it would be up-converted to full HD and ATEM recognize this as 1080i50?:)
    Liudas Vasaris replied 14 years, 7 months ago 3 Members · 4 Replies
  • Justin Strauber
    February 16, 2012 at 4:33 am
    Not entirely sure in your case, but you would probably need an UpDownCross after the analog->SDI converter in order to get things to the right format. I don’t have an HDV camera, all of mine are straight 1080i, so I can’t tell you with certainty.
  • Liudas Vasaris
    February 16, 2012 at 8:01 am
    There are many threads about XHA1-component and possibility to output 1920×1080, but as I understood it just upscale 1440×1080. I was wondering maybe converter upscale signal as well?
  • Martin Kraut
    February 16, 2012 at 11:10 am
    I think the XHA1 will output FullHD on the analog output connection and not 1440×1080. It means that your camery will automatic upconvert from HDV to FullHD
  • Liudas Vasaris
    February 16, 2012 at 11:40 am
    Thanks. As I thought:) Probably same with all HDV camcorders like fx1?
    One more big advantage for ATEM!
