HDV Better Work Flow (Please Help)
I have a Mac Pro with 2 gigs of ram and a RAID Media Drive. I’m editing shows for Discovery Health Channel shot on the Sony Z1U in HDV. Here is my issue, I’m hoping somebody can help me.
1. I capture everything in HDV and edit in HDV so that when I go to give it to the online house they don’t have to recapture.
2. I frequently have to put up MPEG4 files on the Discovery FTP server so that EPs can view the cuts. The shows are around 44:45 long.
3. Here is the current work flow I’m using to go from my HDV timeline to MPEG 4 (320X180)
a. Mark In and Out
b. Use compressor to spit out an HDV 1080i60 quicktime.
c. Use quicktime Pro to convert to an MPEG4 using custom aspect ratio of 320×180 so that it ends up as a rectangle and not a squished square.THE PROBLEM…
If I go straight from my final cut sequence to MPEG4 the sound sync gets off which is why I’ve had to use this work around. IT TAKES FOREVER!!! For example, right now I’m exporting a 23 minute timeline to my desktop using compressor, it says 1 hour and 13 minutes to finish it, plus another hour to go from quick time pro to the mpeg4 (320×180).
I’m not looking to use ProRes or anything else because it will scew up my work flow with the Online Editing House.
Does anybody have a quick work around to go from my HDV sequence to a downloadable low res but still okay looking watchable mpeg4? The amount of time I’m sitting around waiting is allowing me to make posts like this.
Somebody please help!!! Thanks.
