Activity › Forums › VEGAS Pro › HDV Batch Capture via firewire with timecode?
  • HDV Batch Capture via firewire with timecode?
    Posted by Rick Redondo on September 18, 2010 at 5:33 pm
    Does anyone know if it is possible to batch capture with timecode HDV from my FX1 via firewire through Vegas 9? This wasn’t possible with Vegas 8, and I don’t want to purchase the upgrade to 9 if I’m not positive it will work. I understand that Final Cut Pro can batch capture HDV via firewire no problem, and so I may just have to make the switch.
    Thanks for your help,
    Rick
    John Rofrano replied 16 years ago 2 Members · 1 Reply
  • John Rofrano
    September 19, 2010 at 12:01 pm
    No, batch capture is not possible with HDV and since Sony hasn’t fixed the bugs with scene detection, I doubt highly they are going to start adding new features to a dieing format. With hard drives being so cheap, just capture the whole tape and delete the scenes you don’t want. It is faster than going through the whole tape twice; once to mark the capture in/out points and second time to actually do the capture.
    Haven’t you heard? Vegas Pro 10 is being released Oct 11th. I won’t upgrade to 9 now; I would wait and upgrade to 10.
    That is not a trivial switch unless you already have a Mac are use to having a very limited software selection. 😉 Good luck.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
