Activity › Forums › Adobe Premiere Pro › HDV Batch Capture Failure
  • HDV Batch Capture Failure
    Posted by John Goerner on November 21, 2005 at 7:36 pm
    I can’t get Premiere Pro to do a batch capture in HDV. I’m using the Sony Z1u in HDV mode. I can control and log just fine. I can also caputre on the fly. But I try to do a batch capture and premiere sends the VCR into fastforward never to return?
    What gives?
    BTW Batch capture works just fine in DV mode with the same equipment.
    Thanks.
    John
    John Goerner replied 20 years, 10 months ago 2 Members · 2 Replies
  • Mike Newman
    November 22, 2005 at 5:02 pm
    Are you using the bought version of Aspect HD or just the Premiere v1.51? I think batch capture is only implemented in the full version.
    Mike Newman Production
    Broadcast and multimedia producer
  • John Goerner
    November 22, 2005 at 5:09 pm
    The version that came with Premiere. Over in creative calf I was told that this is a known issue when the timecode is set manually and that it has been discussed in this forum extensively. However I must be searching for the wrong words as I can’t seem to locate it.
    John
    Non-Stop Productions
