Activity › Forums › Adobe Premiere Pro › HDV Batch Capture Failure
  • HDV Batch Capture Failure
    Posted by John Goerner on November 21, 2005 at 7:36 pm
    I can’t get Premiere Pro to do a batch capture in HDV. I’m using the Sony Z1u in HDV mode. I can control and log just fine. I can also caputre on the fly. But I try to do a batch capture and premiere sends the VCR into fastforward never to return?
    What gives?
    BTW Batch capture works just fine in DV mode with the same equipment.
    Thanks.
    John
    John Goerner replied 20 years, 10 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    November 21, 2005 at 8:18 pm
    Did you manually set the timecode on the tape so that it starts at 1 hour or later? If so, this is a known issue. Suggest you head to the CreativeCow Premiere Pro forum, as this issue has been discussed there quite a bit.
  • John Goerner
    November 21, 2005 at 8:40 pm
    Yes I did set TC Manually. Thanks I’ll look over there.
    John
