Activity Forums Apple Final Cut Pro Legacy HDV Batch Capture and sequence questions
  • HDV Batch Capture and sequence questions
    Posted by Lee Burrows on August 30, 2005 at 1:09 am
    Hello. My thanks to Andy Mees for giving me some great advice earlier today. I enjoyed the article about HDV by the developer of HDVxDV. <https://www.kenstone.net/fcp_homepage/hdvxdv_wright.html> Interesting article.
    I am currently capturing in HDV right now and wanted to know why does FCP make you scratch and claw to figure out that you have to set your capture and device presets for HDV in audio/video settings before intializing the the log and capture window to get that special log and capture HDV window? Why can’t it be just another codec offered under the regular log and capture window? Also is there a way to turn the preview monitor on(like it is when you capture analog video) for the special HDV log and capture window so that you can reference the video another way besides using the deck monitor?
    If I don’t want to down convert and want to work in native HDV then what is the best Sequence codec that I should use that would allow me to import the HDV footage into it without rendering? If this is not possible then what codec is the best to use for my sequence? In the article that I read earlier, HDV Apple Intermediate Codec was praised. Will this give me good quality?
    Thanks in advance for any advice. I’m running FCP studio on a G5.
    Lee
    G5 Mac OS X
    Dual 2.0 GHz
    FCP 4.5 HD
    XServe Raid 1 Terabyte
    G5 Mac OS X
    Dual 2.3 GHz
    FCP 5.02 Studio
    G-Tech G Raid 500 GBs
    2 – Lacie Drives 200 GBs
    Lee Burrows replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
