Activity Forums Apple Final Cut Pro Legacy HDV Audio Sync Drift nightmare
  • HDV Audio Sync Drift nightmare
    Posted by Steve To on December 10, 2008 at 8:53 am
    40minute film
    PAL 1080i50 HDV
    render codec set to PRORES, seq codec set HDV
    Footage ingested from FS4 and MRC1 units and all in synch on timeline, and has worked perfectly in other HDV projects
    I’m editing a 40minute film with all footage fine on the timeline, but whenever I export (to a same as sequence reference or self contained .mov file) the audio drifts by about 5mins into the film!
    I’ve cleared out all render files, re-rendered, and exported again and still audio drifts AHEAD of the video?!
    Previously clearing and re-rendering the composit timeline has worked, but this project after the 3rd output it’s STILL out of sync.
    Can anyone help with a solution?!
    Steve
    Steve To replied 17 years, 9 months ago 2 Members · 4 Replies
  • Kevin Monahan
    December 10, 2008 at 4:33 pm
    What drives are the clips on? Your Mac HD or an external?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Steve To
    December 10, 2008 at 4:35 pm
    The clips are on an external drive, and exporting back to the same external drive.
    thanks
    Steve
  • Kevin Monahan
    December 10, 2008 at 6:30 pm
    Drifting synch usually has to do with the following:
    1. Slow drives like USB 2.0
    2. FireWire or Secondary drives that are full to the brim
    3. Render Files or Media Files that exist on the Mac HD
    4. Separate System Sound wrongly imported/captured
    Could this be you?
    Kevin Monahan
  • Steve To
    December 10, 2008 at 9:15 pm
    Thanks.
    I only use FW800, and try not to have them full, although does happen so good advice 🙂
    I cleared out every audio and video render file – using render manager – and then wiped all the attached drives render folders and did the render and self contained export all over again, and thankfully it worked this time!!
    I guess I just need to have a full clearout before rendering out the final composite next time!
    Thanks again
    Steve
