Activity › Forums › Apple Final Cut Pro Legacy › HDV as Pro Res in ProRes LT TImeline to SD DVD?
  • Jerry Hofmann
    April 6, 2010 at 7:09 pm
    I see no reason at all to export a downconverted file first… just go right at compressor and do the deed from the ProRes LT sequence I’d suggest.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • John Fishback
    April 6, 2010 at 9:42 pm
    I do this all the time with DVCProHD footage. I export a QT using Current settings and use that HD file in Compressor to make the SD mv2 & ac3 files.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
