Activity Forums Apple Final Cut Pro Legacy HDV and Final Cut
  • HDV and Final Cut
    Posted by Aps1234 on February 7, 2006 at 7:24 pm
    Hello there,
    I work on a tv show that is shot on HDV. What should i do when dealing with 4:3 archive footage as it comes up small within the HDV interface. Should i just enlarge to an accpetable level and live with it??
    Also when i am not getting the full benefits of RT even though i am working on dual 2.7 processor with 4 gig RAM. Sotimes even a clip with no fx needs to be rendered.
    Has this to do with A/V and system settings and the codec format i am digitzing in?? we are using an HDV player and also a j30 player for digibeta and sx footage, therefore we are switching between formats.
    Thankyou
    Aps1234 replied 20 years, 7 months ago 2 Members · 2 Replies
  • Creative Animal jan
    February 7, 2006 at 7:50 pm
    Are you using any video interface such as Blackmagic or AJA?
    If you do, the problem is easy: your sequence settings are not the same as your clipsetings (command-0 and command-9)
    try matching them.
    If you use a blackmagic interface, select HDV1080 as a sequence preset and choose HD1080 in your playback tab in the audio video settings menu.
    Then, in the system preferences of the mac itself, choose blackmagic settings and enable realtime HD->SD downconversion.
    that should do it.
    regards
    Jan
    managing director
    Creative Animal
    The Netherlands
  • Aps1234
    February 8, 2006 at 7:13 pm
    Thaknyou very much will try that out
