Activity › Forums › Adobe After Effects › HDV and AE moving slow
  • HDV and AE moving slow
    Posted by Evideom on December 21, 2007 at 3:57 am
    I just got a new HDV camcorder, I am trying to mess around in AE but AE is moving very slow. I can’t even scroll the preview “no effects” window and AE jst stops moving.. I have a dual core machine with the 3 gig switch on. The file type I am using is an .m2t, what should I be doing or is what AE does with HDV footage?
    Evideom replied 18 years, 9 months ago 4 Members · 4 Replies
  • Steve Roberts
    December 21, 2007 at 5:28 am
    Yes. Just search the COW for “HDV” and “slow”.
  • Alfonso Gamez jordano
    December 21, 2007 at 10:07 am
    Use proxies
  • Amit Zinman
    December 21, 2007 at 10:22 am
    You should be using CS3 (you should also get some boost if you use Vista) which is faster with HDV material and enable multiprocessing.
    If this doesn’t work for you, render the file to quicktime animation and it should run faster.
    __________________________________________________
    See my stuff at https://www.youtube.com/amitzinman
  • Evideom
    December 21, 2007 at 10:50 pm
    Thank you,
    I tried using the search engine the first time but whatever I put in the engine did not yield the results that “HD and slow” did. I did check out Andrew Kramers proxy tutorial which was very nice. Any recommendations on what is the best codec to use?
    Jarrod Fegley
