Activity › Forums › Adobe After Effects › HDV and AE (i searched and read past posts – still confused)
  • HDV and AE (i searched and read past posts – still confused)
    Posted by Frank Pledge on November 10, 2006 at 10:50 pm
    i KNOW this has been asked as i read many posts but still am lost.
    i have an HDV1080i project in FCP. i wanted to do some title treaments and fix/create some graphic elements in AE. for the titles i export a self contained fcp movie in native (hdv) format.
    i’ve read all these posts about how AE seems to interpret HDV ‘wrong’. i have AE 7 and it is giving it the 1920×1080 aspect. shouldn’t it be 1440?
    so my comp settings (when i drag the media onto create new comp auto thing) creates a ‘custom’ setting with an HDV pixel aspect ratio.
    it looks right though. if i change the comp setting to hdv from custom or type in the aspect ratio it goes 4:3 but does not ‘squish’ the media. it creates something closer to a 4:3 mask.
    ALSO – when i render out from what AE wants the comp to be with upper field first and in HDV codec here’s another wierd thing – it stutters and drops frames on playback in FCP. even though when i cut it into the hdv timeline it does NOT want a render – meaning to me – that the media ‘matches’ the seq settings. it’s not the hard drive struggling as i have a 3 drive sata array.
    i’m utterly lost.
    thanks for any insights and help
    fp
    Straight A replied 19 years, 10 months ago 2 Members · 9 Replies
  • 9 Replies
  • Straight A
    November 11, 2006 at 12:20 am
    My experience exporting HDV footage (from FX-1 / Z1 and HV10) using FCP (set up as either HDV 1080i codec or HDV intermediate 1080i codec) to use in After Effects:
    After Effects seems to interpret FCP HDV footage incorrectly. When AE stretchs the FCP HDV footage from 1440*1080 to its correct aspect ratio of 16:9 – 1920*1080i, the horizontal interpolation is terrible, it is almost as if you are loosing half the horizontal resolution. The very same files played back in Quicktime player or VLC or FCP or MPEG Steamclip looks as it should, with smooth horizontal interpolation from 1440 to 1920.
    I have tried this route (HDV >> FCP >> AE 7) on a few systems and it is a consistent problem. (ie: it is not my machine only)
    No combination of comp + footage setting will solve the problem (believe me when I say I have exhaustively investigated this!!)
    Their are two ways around this problem if you are troubled with it.
    1) Capture in iMovie and not FCP – the quality is the same and files import into AE as 1440*1080 and not 1920*1080, thus allowing the footage to be interpolated to 1920 within AE using AEs very good interpolation algorithms.
    2) If you insist on capturing in FCP, open the files – you wish to later import into AE – with Quicktime Pro and change the video header information from 1920*1080 to 1440*1080 and hit save – (even massive files will save in a second or two as all you are doing is altering the header and not actually changing any data).
    Both these routes result in footage that interprets correctly in AE.
  • Straight A
    November 11, 2006 at 12:24 am
    P.S.
    Set your comp setting up as 1920*1080 with square pixels.
    Interpret your footage as sqaure pixels.
    When you put a new piece of footage onto the time line hit Command+Option+F (Mac) to fit the footage to the comp.
  • Frank Pledge
    November 11, 2006 at 1:40 am
    thank you thank you. gonna try that.
    do you ever find playback in FCP on your AE movies are dropping frames like crazy? my render settings SEEM correct as they match the timeline in FCP aka – they do not need a render to playback – but then don’t playback…
    thanks again, gonna give it a go
    fp
  • Straight A
    November 11, 2006 at 11:21 am
    Hmmm…
    sounds strange ?
    In theory if the render bar does not appear you should be good to go and FCP should play back just fine ?
  • Frank Pledge
    November 11, 2006 at 1:01 pm
    tell me about it. the media also sits on a sata raid array. very very strange. thanks
    fp
  • Straight A
    November 11, 2006 at 2:17 pm
    I tried your exact workflow:
    input-HDV into FCP >> output-HDV >> input-HDV into AFTER EFFECTS >> output-HDV >> input-HDV from AFTER EFFECTS into FCP.
    I suspect your problem is not outputting the right codec from AE. (? possibly ?)
    Double check what your FCP project was set up with – HDV / HDV Basic or HDV intermediate etc – and make sure you output the same codec from AE – and that your AE frame size is identical (if using the HDV codec that should be 1920*1080).
    I output using the HDV codec and FCP did not like that, so I tried the Apple Intermediate Codec (A HDV codec) and it worked fine in FCP, no need to render and playback was fine.
  • Frank Pledge
    November 11, 2006 at 3:19 pm
    will try intermediate codec. i think you may have nailed it as i have read about using this codec, but thought that it was ‘old’ info. meaning that FCP had become more HDV native.thanks so so so much!
    fp
  • Straight A
    November 11, 2006 at 4:32 pm
    This will only work if your FCP project is set up as ‘Apple Intermediate codec.’, which it may be as it is a HDV codec.
    As far as I know the Apple intermediate codec is pretty much the same as the HDV codec, except that it gets around the editing problems of HDVs GOP (group of pictures) compression protocol, (HDV records one perfect-ish frame and then renders only the changes from this ‘perfect’ frame over the next 15 frames) – the intermediate codec ‘freezes’ these 15 ‘interframe’ images that reference the ‘perfect’ frame, so they no longer reference the ‘perfect’ frame but are self contained frames ‘real’ frames.
    Or something like that !!
    Whatever your FCP project is set up as, be it HDV / HDV intermediate / DV / DVCPro / HDV Basic etc etc, you will need to export from AE in exactly the same codec and at the exact same frame size, your only choice is over audio output (as far as I can see, although I have not tested many options) and these options are either exactly the same as the settings for the HDV footage you import into AE or no audio.
  • Straight A
