Activity Forums Blackmagic Design HDV and 720p24 DVCPro HD? Which Decklink?
  • HDV and 720p24 DVCPro HD? Which Decklink?
    Posted by Lee Chatameticool on December 27, 2006 at 9:34 pm
    Any advice would be most appreciated. I’m setting up a system to edit HDV and 720p24 DVCPro HD (both acquired natively through firewire). The following are what I need:
    1. Realtime HDV 1080i50 and DVCPro HD 720p24 to SD downconversion on analogue outputs to monitor on an SD monitor while I edit.
    2. Realtime HDV 1080i50 and DVCPro HD 720p24 to Uncompressed HD 1080 crossconversion.
    3. Realtime Color Correction.
    3. Component in to capture Beta SP
    4. Ability to monitor on consumer grade HDTV with HDMI or DVI-D inputs
    Is there a decklink setup that would enable me to do this? I’ve tried searching through this forum and going through the specs but am still unclear as to how much Deckling supports native DVCPro HD and HDV.
    Lee
    Intel Quad 2.66 Mac
    2gb of Ram
    External SATA Raid
    Lee Chatameticool replied 19 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
