Activity Forums Adobe After Effects HDV AE interpretation?
  • HDV AE interpretation?
    Posted by Dflamholc on January 21, 2006 at 12:09 pm
    Hi all,
    AE interprets my 1440×1080 HDV material (shot on sony’s Z1U) to non-square pics, while the comp settings for HDTV in AE only gives me square pics (which then results in stretched video material when i pop it in to a comp – even though same dimensions in both settings i.e. 1920 x 1080).
    Am i clear to re-interpret the footage to square pics, which makes it fit in nicely?
    As far as I can see right now I should be OK, or are there problems waiting ahead?
    Also, I was expecting to having to do a pull-down on the HDV clips, but AE can’t do one (if I press the guess pulldown button in the interpret footage dialogue nothing happens…???
    Any advice on these two things would be greatly appreciated!
    Thanks in advance!
    /d 🙂
    Dflamholc replied 20 years, 7 months ago 2 Members · 2 Replies
  • Andrew Yoole
    January 22, 2006 at 2:19 am
    Check my post in a previous thread for establishing interpretation rules for HDV. (If you upgrade to AE7 you won’t need to worry – it’s all included).
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=867696
    You don’t need to use pulldown.
  • Dflamholc
    January 22, 2006 at 2:43 pm
    wow, cheeers for that! it worked a charm getting those new settings into the drop down menues,.,.
    my problem now is that i’ve already gone agead an created a bunch of graphic sequences in 1920×1080 comps that I now have to put my hdv footage into… if I choose the new 1.33 option they’re still stretched in those comps. however if I interpret the hdv footage as square pixels then they look fine? what do I do? is there a big quality loss if I interpret the hdv as square pix rather than 1.33?
    sorry if I’m being thick and not seeing something obvious here, while struggling to hold back panic 🙂
    thanks again, d
