Activity Forums Apple Final Cut Pro Legacy hdv 50i to 24p or 25p?
  • hdv 50i to 24p or 25p?
    Posted by Susanto Widjaja on January 8, 2006 at 9:52 pm
    hi,
    Im editing an independent feature film shot in hdv 50i mode. Im thinking to convert the final output into either 24p or 25p but haven’t got experience of doing it. Im wondering if 24p is better than 25p, and what is the best way converting it. I’ve read about nattress and noticed that it only allows 60i to 24p but not 50i to 24p. I also wondered if we could do the deinterlacing ourself and still getting a good output without the need of buying the plugin.
    Also i have a magic bullet editor version1. can it be used with hdv?
    thank you very much and sorry for the long questions.
    thanks
    Jack
    Graeme Nattress replied 20 years, 8 months ago 2 Members · 5 Replies
  • Graeme Nattress
    January 8, 2006 at 10:06 pm
    Bump your HDV to uncompressed. De-interlace. Use Cinema tools to conform to 24p. No extra software needed, unless you need a nice de-interlacer.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Susanto Widjaja
    January 11, 2006 at 1:20 am
    hi,
    I’ve tried the demo filters from nattress,
    whats the differences between those de-interlacers? they all seems the same to me.
    Which package should I buy if I want the 50i -> 24p/25p stuff.
    I assume that the package would be the standard conversion, but Im just wondering if Film Effects filter also has the same conversion effects.
    thanks,
    jack
  • Graeme Nattress
    January 11, 2006 at 1:25 am
    You’ll need a real HD monitor to see the difference in the de-interlacers. FCP doesn’t show interlaced video right, so it’s going to be hard for you to tell. They all look subtley different.
    For 50i to 24p, you need to de-interlace, bump the video to uncompressed, and use cinema tools to conform. That’s the best way.
    Graeme
  • Susanto Widjaja
    January 11, 2006 at 1:35 am
    which one do u think is better to go into DVD? 25p or 24p? cause i heard some problems happens when u convert 50i to 24p.
    Also which one is the right package for me to buy from nattress? Could you please explain?
    thank you very much
    Jack
  • Graeme Nattress
    January 11, 2006 at 1:40 am
    Jack, I need to know more about the project and audience to answer 25p or 24p fully. You can do all of this with the in-built tools in FCP, Quality of de-interlace doesn’t matter for going to DVD as it’s so much lower resolution than HD.
    Graeme
