Activity Forums Apple Final Cut Pro Legacy HDV 50I and 25p to 25p workflow
  • HDV 50I and 25p to 25p workflow
    Posted by Andy Yoong on December 17, 2008 at 7:55 pm
    My first post here! I am working on a project shooting with a Canon Xh-A1. My footage is a mix of 25p and 50i HDV. I would normally shoot everything at 25p but the 50i setting allows me to do smooth slow motion. I have a few questions about optimum workflow.
    What should my sequence settings be if I want to output progressive footage. Is it best to put all of the 50i and 25p on a 25p timeline, and will this deinterlace the footage, or should I use a 50i timeline and try to de-interlace another way? (I have nattress smart deinterlacer) Do the individual clip settings have to be changed in any way?
    Andy Yoong replied 17 years, 9 months ago 2 Members · 2 Replies
  • Michael Gissing
    December 17, 2008 at 9:42 pm
    HDV shot on the Canon is 50i. The 25p setting is psf which means a progressive image segmented into a 50i signal. So you 25p material is actually 50i with identical fields.
    The correct setting is HDV 50i in your easy setup. If you wish to deinterlace then the Nattress filters are good for that.
  • Andy Yoong
    December 17, 2008 at 10:19 pm
    Do I need to change the field dominance settings in either the time line or the 50i or 25p clips? I have in the past used a hdv 25p timeline with no field dominance. Does this produce progressive footage? Is this a bad workflow and if so why.
