Activity Forums Apple Final Cut Pro Legacy HDV 1080i50 to DVCAM NTSC
  • HDV 1080i50 to DVCAM NTSC
    Posted by Per Stålka on August 11, 2008 at 6:16 pm
    Hi
    I need a good workflow with FCP and Compressor to go from HDV 1080i50 to DVCAM NTSC.
    I’ve tried to do the frame rate conversion and downscaling in Compressor, and output to a SD with DV/DVCPRO NTSC codec. When I open it in FCP to write to DVCAM it gets all jaggy. The same when I view my output file in QuickTime player. Strangely, the file looks good in VLC player – though VLC have a problem playing it back in realtime.
    I’ve tried to output the SD file in number of different codecs. It looks great in AIC, Apple Pro Res but when I use these codecs I can’t get it to scale correctly inside FCP.
    Can someone advice on a good workflow using FCP and Compressor?
    Best regards,
    Per
    Rafael Amador replied 18 years ago 2 Members · 1 Reply
  • Rafael Amador
    August 12, 2008 at 3:02 am
    Hi Per,
    From HDVi50 to DV NTSC you need to change many things: Size, pixels, field order, time base…
    I wouldn’t do all the process at once as you are trying.
    First I would make an SD PAL movie and from there the NTSC movie.
    rafael
    http://www.nagavideo.com
