Activity Forums Apple Final Cut Pro Legacy HDV 1080 50i into Pal sequence, which HDV codec?
  • HDV 1080 50i into Pal sequence, which HDV codec?
    Posted by Dag Mykland on February 9, 2009 at 9:09 am
    Hi.
    I have read an awfull lot about this, trying to figure this out on my own.. But no luck.
    My setup is as follows:
    – Dual 2.8 Quad Core Intel
    – 4gb memory
    – Lacie external drives through FW800.
    – Sony HDV Deck (Sony HVR M15E or the Sony HVR 1500)
    What I need to do is to be able to capture HDV material in HDV quality or greater, and use it in an DV/Pal sequence.
    Most of people have said “use ProRes”, but the problem is that this project needs to be able to batch up later on..
    And that will be a problem using ProRes, won’t it?
    Can someone please recommend what to do?
    Dan Atkinson replied 17 years, 7 months ago 2 Members · 1 Reply
  • Dan Atkinson
    February 9, 2009 at 10:45 am
    Log and capture to HDV 1080i50 then use media manager to recompress to Pro-res.
    Dan
