Activity Forums Adobe After Effects HDTV (Rec. 709) vs Rec.709 Gamma 2.4 – Video Output
  • Andrew Somers
    September 18, 2018 at 4:08 am
    Hey Nick, to add, I just ran across this info graphic that (hopefully) should make the Rec709/Rec1886 issue very clear:
    Andrew Somers
    VFX & Title Supervisor
    https://www.GeneralTitles.com
  • Eric Santiago
    September 18, 2018 at 11:38 am
    Good lord I have to save this post in my tech book ????
    Thanks, Andrew.
  • Emir Ezwan
    November 8, 2019 at 11:03 am
    Hi Andrew Somers,
    Thank you for the detailed info. May I know what is your recommended workflow for DCI P3 output for AE?
  • Andrew Somers
    November 8, 2019 at 6:33 pm
    Hi Emir,
    The short answer is “it depends” as I don’t know anything about your project — what are your source files, what are you rendering to, and where are those files going next, and what does the DI need, etc etc. I can’t answer your question without specifics.
    Here is an article I wrote some time ago on workflow considerations that might be helpful:
    Scene Referred Colorspace
    In general, today I mostly recommend not using ICC color management for video/film projects. Instead OpenColorIO is a more useful tool for the job, and it’s free.
    Cheers
    Andy
    Andrew Somers
Page 2 of 2
