Activity › Forums › Adobe After Effects › HDTV preset: shouldn’t it be at 25fps?
  • HDTV preset: shouldn’t it be at 25fps?
    Posted by Marco on May 25, 2006 at 2:06 pm
    When I create a project using the HDTV preset AE7 sets the fps to 24: am I wrong or it should be 25?
    Marco replied 20 years, 4 months ago 2 Members · 2 Replies
  • Mylenium
    May 25, 2006 at 2:19 pm
    No, the preset is meant to represent 24p (as in progressive), which is a “neutral” setting. You have to set your fps manually. You could also create a simple script that does it, since obviously this is needed quite often.
    Mylenium
    [Pour Myl
  • Marco
    May 26, 2006 at 11:31 am
    Thanks for the info 🙂
