Activity Forums Panasonic Cameras HDSDI Downconverters
  • HDSDI Downconverters
    Posted by Linda Danchak on August 4, 2005 at 8:16 pm
    I’ve been looking for a feasible downconverter to use on location that may be used with either a laptop and/or any additional SD monitors. I’ve noticed both onboard and miniature models. What are you using with your Varicam? How have you dealt with audio playback on location?
    Tony replied 21 years, 1 month ago 4 Members · 3 Replies
  • Gary Adcock
    August 5, 2005 at 3:33 pm
    [Linda] “‘ve been looking for a feasible downconverter to use on location that may be used with either a laptop and/or any additional SD monitors. I’ve noticed both onboard and miniature models. What are you using with your Varicam? How have you dealt with audio playback on location?”
    I use AJA’s HD10MD3 Mini Downconverter, it has been a standard in my HD kit since the beginning, it solved a number of issues in the early days of HD.
    As for audio monitoring that is the sound guys problem
    gary adcock
    Studio37
    HD and Film Consultation
  • Rodrigo Lizana
    August 7, 2005 at 3:21 am
    I
  • Tony
    August 8, 2005 at 4:15 pm
    Linda,
    For audio use a Rane audio delay box which allows you to input millsecond delay values. I believe the unit I use all the time is a AD22.
    Anyway you can rent them cheaply at any major audio or high end HD video facility.
    The unit has two audio channels input and output.
    You will need to consult with the maker of the downconverter to ask how long the video delay time value is to set the correct millsecond time value in the Rane audio delay box.
    One last note I have to disagree with the posters who choose to make it the audio guy’s responsibility to figure this one out. Working as a team both the DIT/video engineer and soundman can work together to solve a common problem for the client which results in making the job go smoother and easier for all members of the production team.
    Tony Salgado
    “Knowledge is power… power is change”.
