Activity › Forums › DaVinci Resolve › HDRx workflow… How to?
Posted by Pablo Villegas on August 14, 2011 at 9:55 pmHi, I’m just learning resolve 8 and I want to know how to mix an EPIC HDRx sequence?
Thanks in advnaced.
Pablo Villegas replied 15 years ago 2 Members · 4 Replies -
Danny Scotting
August 15, 2011 at 5:06 amPage 219 in the manual says it all……….
Danny Scotting – Senior Colourist
Post Op Group Sydneyhttps://postopgroup.com.au/site/?page_id=1052
Pablo Villegas
August 15, 2011 at 5:30 amThanks.
I read that part, and I can do the mix with the Key Gain slider, which is a lot like the HDR blend slider on Redcine X.
So this is all you can do? Or is there an advanced technique to get better results? I tried doing an HSL Key, but the results were awful.
Danny Scotting
August 15, 2011 at 6:44 amIts good to get a nice balance in the first image before you mix the images, also if you pull a key only do it in one of the nodes. Then after the layer mixer have a play with keys and effects with both nodes already blended.
Good luck.
