Activity › Forums › Maxon Cinema 4D › HDRI problems
  • HDRI problems
    Posted by Kevin Cook on November 3, 2010 at 1:47 am
    I’m trying to light a sports stadium using HDRI. My camera is situated in the bowl of the stadium. I can’t seem to get direct sunlight in my shot. The HDRI image shows a sun and seems to be bright but when I render it out, it looks like my model is in the shadows. I try to turn my sky object around but it doesn’t seem to change anything. I know it’s working because I can see the color values lighting the scene, I’m just not getting bright light. When I try to set the luminance channel to 200% etc., it doesn’t seem to do anything.
    Anyone know what I’m doing wrong? Am I expecting too much from HDRI? Is this an impossible question to answer because you don’t know what my HDRI looks like? Thanks.
    Kevin Cook replied 15 years, 11 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    November 3, 2010 at 12:29 pm
    Do you have Global Illumination turned on in Render>Effects?
  • Kevin Cook
    November 3, 2010 at 5:04 pm
    Yes.
  • Kevin Cook
    November 3, 2010 at 6:23 pm
    I think I’ve figured out my problem; linear workflow is screwing me up in v12 but I’m starting to get a handle on it. Some of my settings (color/project etc.) weren’t set to linear. As soon as I got everything pointed in the linear direction, it started to pop.
    Also, I was using an hdri image that was 3000 pixels wide. I bought a hdri image that was 7000 pixels wide and that made a difference as well, but the linear thing is what was really holding me back.
    If anyone has any other ideas; I’d like to hear them but I think I’m on the right track now.
