Activity Forums Maxon Cinema 4D HDRI not effecting material
  • HDRI not effecting material
    Posted by Simon Hutchinson on April 23, 2009 at 5:50 pm
    Hi there,
    I have an HDRI applied in the environment channel on a glass material, the image appears in the texture area in the material editor but it has no effect on the material preview or in the render. What am i doing wrong? (i have advanced render).
    Cheers,
    Jethro.
    Franco Andrade replied 17 years ago 3 Members · 4 Replies
  • Simon Hutchinson
    April 24, 2009 at 9:46 am
    Responding to my own post, but to not answer a question that you know the answer to would be sacrilege. I found the answer on another forum:
    Hi there,
    you’re right, it only appears if you have it lower than 100% transparent, even 99% works. Maxon have changed the way glass materials work quite a bit in R11, so it’s not too surprising. So in this case I just recomment to use transparencies slightly less than 100% to get virtually the same result.
  • Lawrence Digges
    July 30, 2009 at 8:50 am
    Man, thank you so much for coming back to answer your own question! I’ve been trying to figure this out for an hour and would still be in the dark if you hadn’t.
    Thanks again,
    LD
  • Simon Hutchinson
    July 30, 2009 at 1:45 pm
    Sometimes you will feel like smashing your comp or switching apps because of annoying issues. I am glad my words helped someone else. Communities that have given me so much deserve a little putting back every now and again.
    Jethro
  • Franco Andrade
    September 1, 2009 at 9:14 pm
    I would also like to thank you for answering! Help me, I was stucked on this. Thanks!
