Activity › Forums › Apple Final Cut Pro Legacy › HDMI to SDI Conversion
  • David Roth weiss
    April 20, 2007 at 3:47 pm
    As Wally found out on te Kona Forum, the Hi5 goes SDI to HDMI, not the other direction. However, it does have a very useful purpose for many here, as I pointed out to Walter on the Kona Forum.
    The Hi5 allows those of us with Panasonic plasmas to use an inexpensive Panasonic HDMI board ($145 on ebay) for those monitors as an alternative to the very expensive Panasonic SDI board ($1600).
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Chris Borjis
    April 20, 2007 at 4:12 pm
    Yeah thats some good cash savings there.
    The Panny Plasma SDI Blade is $ 1,500 and the HDMI one
    is $ 500, I couldn’t see spending 1,000 more for something
    I likely would not see any difference in.
  • Walter Biscardi
    April 20, 2007 at 5:49 pm
    [David Roth Weiss] “As Wally found out on te Kona Forum, the Hi5 goes SDI to HDMI, not the other direction. However, it does have a very useful purpose for many here, as I pointed out to Walter on the Kona Forum.”
    Thanks David! I was at lunch when that came out, thanks for the prompt placement on this forum!
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Rennie Klymyk
    April 20, 2007 at 6:13 pm
    [Borjis] “The Panny Plasma SDI Blade is $ 1,500 and the HDMI one
    I likely would not see any difference in.”
    The AJA Hi5 adapter is around $500.00 so you save $500.00 this way and you end up with a converter you can use for your video projector etc etc. I like that it also converts sd-sdi to the hdmi plug and seperates the audio(rca) for routing to your audio set up as well as sending audio to the hdmi plug (into the video monitor). I’m not sure if either of the Panasonic cards split the audio and loop it out for you.
  • Zak Mussig
    April 20, 2007 at 8:06 pm
    Convergent Designs has an HDMI to HD-SDI converter they’ve been pimping here on the COW.
    Zak
