Activity › Forums › Blackmagic Design › HDMI to Dell 24in vs. HDLink to Apple 23″
  • HDMI to Dell 24in vs. HDLink to Apple 23″
    Posted by Eric Hansen on August 24, 2008 at 2:34 am
    i’m currently editing and color correcting in DVCPRO HD 1080i60 and ProRes with the following setup:
    Mac Pro with Kona 3
    HDLink to 23″ Apple Cinema Display
    i’m thinking about building a second editing suite that wont have to capture, but will still need to color correct. will the BM Intensity to the Dell 2408WFP 24″ via HDMI produce a similar high quality result as the Kona 3 to HDLink to ACD? or is Decklink Extreme to HDLink to Dell the way to go? can the Intensity display 2k from Color or only 1080i?
    thanks
    e
    4 G5s, OSx 10.4.11, Final Cut 6.0.2, Kona LH (v5.1)
    Xsan: Xserve 2.0 G5, 3GB RAM, 2 7TB Xserve RAIDs, Sanbox 5200
    Quantum SDLT600A
    decks: Sony HDW-M2000/10 HDCAM, HVR-M10U HDV with HD-Connect, DSR-1500 DVCAM, UVW-1800 BetacamSP
    MacBook Pro: 2.33, 2GB RAM, OSx 10.4.11, Final Cut 6.0.2
    cameras: Panasonic HVX200, Sony FX1 and A1U, Arri S/B 16mm
    skis: Volkl Gotama 183s with 914s and Lange Fluid 120 boots
    Margus Voll replied 18 years, 1 month ago 4 Members · 6 Replies
  • Bob Zelin
    August 24, 2008 at 9:05 pm
    the Decklink Extreme has an analog HD output. This can go directly into the Y Pb Pr inputs of the Dell 2408WFP, and will look very nice without buying anything else. This will NOT display a 2K image.
    The Apple 23″ cinema display will not display a 2k image. If you want a 2k image, the the HDLinkPro and an Apple 30″ display.
    All of these examples you mention will look about the same. The Kona 3 thru an HD Link into an Apple 23″ DVI port will look the same as a Kona 3 (or Blackmagic Extreme) into a 2408 Y Pb Pr analog HD input.
    They will all work.
    Bob Zelin
  • Margus Voll
    August 25, 2008 at 9:52 am
    Hi Bob.
    What about Dell 3008 + HDLinkPro by DVI ?
    Margus
    https://iconstudios.eu
  • Bob Zelin
    August 25, 2008 at 9:38 pm
    never tried it, but it should work, and the Dell 30″ is great !
    Bob Zelin
  • Margus Voll
    August 27, 2008 at 6:14 am
    Hi again.
    Actually i have multibridge pro 2 and i could connect it with hdmi but it does not give me 2x oversize PAL as i see it. This is why i asked about HDLink Pro.
    Annother question is how to adjust Dell as out of the box they have really insane brightness and contrast levels and you could get really nice sun burn in front of them. This is why i have tryed to ask it with LUT’s how to calibrate LCD with HDLink to get reasonable results for color correcting etc. No results for that question yet.
    Margus
  • Chris Torella
    August 28, 2008 at 7:55 pm
    any luck calibrating your HP yet Marcus?, i have the same set up (MB Pro 1) and the same question? I feel the Yellow and the Greens are oversaturated.
    anyone try the HP calibation software yet?
    Chris Torella
    Pickerel Pie Entertainment
    10-26A 46th. Ave.
    Long Island City, NY, 11101
    718.606.9840 O
    718.606.9843 F
  • Margus Voll
    September 1, 2008 at 7:45 am
    Hi.
    I do not have it yet just figuring my options out.
    Margus
