Activity › Forums › Blackmagic Cameras › HDMI Recorder and External Monitor from BMPCC?
Posted by Andy Morin on February 9, 2014 at 12:51 amI’m trying to put together my rig for the BMPCC and i have an IKAN 7′ external monitor ready to go but i want to hook up an external recorder for the long days. Can i just split the HDMI and connect the two to the same output without reduction in quality?
John Fishback replied 12 years, 7 months ago 3 Members · 3 Replies -
John Fishback
February 9, 2014 at 3:59 pmThere are HDMI distribution amps. I’ve never used one, but if it conforms to specs, it should work. As with all “boxes” be suspicious of the lower priced ones.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Matthew Sonnenfeld
February 17, 2014 at 9:38 pmCheck to see if you Ikan monitor support loop through. If this is the case then you can take the HDMI out signal from the monitor and put it to your recorder.
Co-President at fourB Productions, Inc.
Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
2008 Mac Pro 2.6 Ghz 8 Core, 10GB RAM
AJA IoXT, Blackmagic Intensity Pro, Blackmagic Mini Monitor
Adobe Production Premium CC, Avid Media Composer 7, Final Cut Pro Studio 3 -
John Fishback
February 17, 2014 at 9:53 pmOr, if the Ikan doesn’t loop thru, Matthew’s idea might work in reverse. Feed the signal to the recorder and loop out of that to the monitor.
John
