Activity › Forums › AJA Video Systems › HDMI preview
  • HDMI preview
    Posted by Krzysztof Kalukin on June 5, 2009 at 6:23 pm
    Hello,
    I’ve connected full HD LCD display to HDMI output of Kona 3 LHi. Test bars appear, but colors are not correct – white bar is cyan, blue is pink, black is red, etc. That monitor does not have HDMI input, but we used HDMI<>DVI adaptor. Any ideas what’s behind that problem?
    Thanks in advance
    Krzysztof
    Ramona Howard replied 17 years, 3 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    June 6, 2009 at 2:35 am
    [Krzysztof Kalukin] “That monitor does not have HDMI input, but we used HDMI<>DVI adaptor. Any ideas what’s behind that problem?”
    Probably your HDMI to DVI adaptor. What kind of monitor is this? What other connectors does it have?
    [Krzysztof Kalukin] “I’ve connected full HD LCD display to HDMI output of Kona 3 LHi.”
    Is it a Kona 3, or is it a Kona LHi? These are 2 different cards.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Krzysztof Kalukin
    June 6, 2009 at 7:57 am
    That’s iiiyama Pro Lite e2208hds. I conntected that monitor do DVD player using the same HDMI cable – everything is OK. When I connected other LCD monitor to Kona – situation the same – colors are not correct.
    The card is Kona LHi of course.
    Krzysztof
  • Ramona Howard
    June 10, 2009 at 1:16 am
    Don’t forget to add that you can push ANY colorspace down HDMI and DVI you can not!
    So start with the content, is it higher than 8 bit 4:2:2? If it is then, guess what, it won’t look the same no matter what you do.
    If it is only 8bit 4:2:2, then move onto the next issue to rule out.
    Best of luck
    Ramona
    Play hard today, it may be raining tomorrow!
